Subbububbu
Oct 15, 2018Guide
Call of Duty Black Ops 4 and Geo Filter
Hi,
I live in a region without Dedicated Servers for Black Ops 4, and frequently used the Geo-filter function previously in CoD WWII successfully.
I've run into a big snag when it comes...
Stevecook
Oct 31, 2018Apprentice
I have the same issue with the xr500. If I have it in filter mode will not find a match. Lobby not joinable. If I put on specting funds a match instantly. I live on the east coast. But it connects to peer not dedicated. There is a dedicated server 200 miles from house put. Connects peer.
- Netduma-FraserOct 31, 2018NetDuma PartnerWhat have you got your radius set to? You should definitely be able to force a game on the east coast. Its likely a dedicated server just misclassified as a peer on the Geo-Filter which we can update, that won't affect your connection.
- StevecookOct 31, 2018ApprenticeRadius is set to 400 miles. I can find a game if geo is on spectating but in filter mode will not. The host is named peer. It is in same location as the dedicated server I play on sometimes but has a different ID number than the dedicated one.
- Netduma-FraserOct 31, 2018NetDuma PartnerTheres many servers located in the same cluster, they're likely just misclassified as peers on the Geo-Filter which can be updated, doesn't affect your connection.
I'd recommend you'd raise that to 650miles. Also do the following:
Remove device from Geo-Filter
Quit game to dashboard compeltely or hard turn off console
Flush cloud on Geo-Filter
Add device to Geo-Filter
Set Geo-Filter radius/location
Boot up console/game, should be able to get a game
