ggabir2
Nov 20, 2022Aspirant
call of duty not filtered on geo filter for PC Xr1000
- Nov 20, 2022Thanks for that, remove the PC from the Geo-Filter, then in the Device Manager change the PC to a PlayStation device type then re-add to the Geo-Filter and select the manual option then you should be able to filter.
ggabir2
https://imgur.com/a/4dYruPl heres the link
Netduma-Fraser
Nov 20, 2022NetDuma Partner
- ggabir2Nov 20, 2022Aspirant
So even if I game on pc. I should follow these steps?
- Netduma-FraserNov 20, 2022NetDuma PartnerYes that's right
- AnonymousNov 20, 2022Seriously, I shouldn't have to do that
Right! Makes me think this router isn’t for gaming pc but for consoles if this is the case.
- AnonymousNov 20, 2022True true. I really shouldn't have to do that though. They should make it fully compatible for gaming PCs and stuff
Yeah.
- AnonymousNov 20, 2022What games do you play though? By the way, I have an XR 450 and it still does this
I have a xr1000 and I play all call of duty’s.
- AnonymousNov 20, 2022Same want to add me
- Netduma-FraserNov 20, 2022NetDuma PartnerIt is the easiest way to filter on PC without changing services every time you want to play a different game, otherwise you can just use the service and switch it to filtering mode
- ggabir2Nov 23, 2022Aspirant
Yeah I can add you I also got the best settings lmk if you want them for your router
- FURRYe38Nov 25, 2022Guru - Experienced User
