ggabir2
Nov 20, 2022Aspirant
call of duty not filtered on geo filter for PC Xr1000
- Nov 20, 2022Thanks for that, remove the PC from the Geo-Filter, then in the Device Manager change the PC to a PlayStation device type then re-add to the Geo-Filter and select the manual option then you should be able to filter.
Retired_Member
Nov 20, 2022It also happens to me it says that it's incompatible but it should be compatible
- Netduma-FraserNov 20, 2022NetDuma PartnerDo the above and it will definitely work for you
