ggabir2
Nov 20, 2022Aspirant
call of duty not filtered on geo filter for PC Xr1000
- Nov 20, 2022Thanks for that, remove the PC from the Geo-Filter, then in the Device Manager change the PC to a PlayStation device type then re-add to the Geo-Filter and select the manual option then you should be able to filter.
Anonymous
Nov 20, 2022It also happens to me it says that it's incompatible but it should be compatible
Netduma-Fraser
Nov 20, 2022NetDuma Partner
Do the above and it will definitely work for you
