ggabir2
Nov 20, 2022Aspirant
call of duty not filtered on geo filter for PC Xr1000
- Nov 20, 2022Thanks for that, remove the PC from the Geo-Filter, then in the Device Manager change the PC to a PlayStation device type then re-add to the Geo-Filter and select the manual option then you should be able to filter.
ggabir2
Nov 23, 2022Aspirant
Yeah I can add you I also got the best settings lmk if you want them for your router
Nov 25, 2022Guru - Experienced User
