Koorsknight
Nov 04, 2018Aspirant
Can’t connect to Internet with XR500
So I just moved into my new apartment and had Fios TV/Internet setup before I moved in. I opted out of renting/buying their router since they really aren’t the greatest and wanted to use my own. I dec...
Nov 06, 2018Guru - Experienced User
Any progress on this?
Koorsknight wrote:
So I just moved into my new apartment and had Fios TV/Internet setup before I moved in. I opted out of renting/buying their router since they really aren’t the greatest and wanted to use my own. I decided to buy a new XR500 to use Fios to maximize the gigabit Internet they offer. So now I’m trying to setup everything since I’ve settled in and I’m having issues connecting to the internet. My ONT box had an Ethernet cable coming out and coax going to it. Plugged the Ethernet WAN into the router and didn’t work. I’ve tried resetting both the ONT box and router multiple times and nothing works. I attempted to release the DCHP while connected directly to the ONT and that didn’t work either nor does it on the router. Really stumped right now since I had to convince my SO this was a smarter choice to get the router. Note: the ONT was already installed I’m assuming previous renters had Verizon.
