cjbutterfly
Sep 19, 2019Guide
Can’t get right speed
Hi , I need help pls . I have a hub 3 200 speed virgin package I have connected the xr500 to the router but with the hub I get 200 speed and with xr500 I get 78 ? Can anyone help me understand why i...
cjbutterfly
Sep 19, 2019Guide
Thank you for your reply , I am sorry I wish I knew more about the routers but I’m just a mom trying to sort ping issues out for her kids :0
I think I kind of understand what your saying though , the virgin hub 3 is the standard router and the netgear xr500 is connected via Ethernet to it . When I turn the virgin hub into modem only the netgear won’t work ? says no internet . I called netgear when I purchased it and they couldn’t figure out why so said to keep the hub as normal and use both but I am getting so much interference in the WiFi signal , a virgin engineer came out and did something to create two channels one said 2g and the other 5g which helped a little but the 2g connection was poop and now I have reset the router to try and gain better internet it’s deleted what he did so I’m in a bit of a pickle
Netduma-Fraser
Sep 19, 2019NetDuma Partner
The WiFi interference can be fixed by disabling the WiFi on the Virgin hub. For speed, are your expected speeds entered into the Anti-Bufferbloat options (looks like 3 stacked lines) on the QoS page?
- cjbutterflySep 19, 2019GuideYes it finds the speeds automatically when I set up the router shows as expected 219 but only ever gives me 79 through the netgear option if I click on virgin I get around 179 to 200 . I didn’t know I could turn off the WiFi on the virgin hub I will look at that now thank you
- FURRYe38Sep 19, 2019Guru - Experienced User
I would contact your ISP and have them help you get the ISP modem configured correctly for one of the options suggested for use with the XR router.
- Netduma-FraserSep 19, 2019NetDuma PartnerDisable smart connect on the XR500 and connect to the 5GHz that should give you higher speeds. Once WiFi is disabled on Virgin then they should both give you better speeds.
