Ghosthunterlife
Mar 16, 2025Aspirant
Can’t I can’t access xr450 pro gaming router to change password. WiFi is there but won’t connect
I received my xr 450 NETGEAR pro gaming router from a friend but I can’t access the router to change the password. The one on the bottom of the router isn’t working. The WiFi is there but I can’t get ...
Mar 16, 2025Guru - Experienced User
Factory reset it. Push and hold reset for 7-15 seconds while its powered on.
that should get it back to the defaults.
Ghosthunterlife
I have already done that and it doesn’t work.
- Netduma-FraserMar 16, 2025NetDuma PartnerHold the reset for 30 seconds then release, wait 4 minutes, then connect via ethernet and enter http://192.168.1.1 and see if you can access. Default credentials are admin / password
