Rick6922
Dec 27, 2018Luminary
can any one tell me what this means in the system log?
I had to turn off power today to install a new dishwasher. when I turned back on I keep disconnecting from xbox live. I'm running new FW. the modem is the netgear cm1000, instant on is off. every ti...
Dec 27, 2018Guru - Experienced User
Means the lease time changed and when this happens the DHCP services disconnect during this event. This will cause a disconnection.
Hopefully suggestions will help you in your other post so this won't happen anymore.
- Rick6922Dec 27, 2018Luminary
no, that didnt work or i wouldnt have asked again.lol but i think i figured it out. in system log it kept saying lease time up . i looked in lan setup and I dont recall the box being checked that says use router as DHCP server. i unchecked that and it hasnt happened again. it was disconnecting every couple of mins. its been fine for last 20 mins. does that make any sense?
- FURRYe38Dec 27, 2018Guru - Experienced User
Yes that would be a cause. DHCP server should always be enabled. Should be enabled by default.
Should be ok now.
