gdwwdg
Jul 16, 2020Guide
can i connect 2 modems to xr700
i have tw0 1 gig inernet accounts and 2 differ modems can i use both on xr700 at same time
- Netduma-FraserNetDuma PartnerNo that isn't possible, you are only able to use the router with one modem at a time.
- gdwwdgGuide
i found a way not directly tho a a multi wan load balancing router mac bridged to give public ip to xr700 that just to make sure no double nat or i just orderd the nighyhawk pro gaming 2/10gig sx10 switch you can use both 10g if no 10g they can be multi wan ports 1gig modem to switch othe1gig modem to switch than switch link aggg to xr700
The SX10 (GS810EMX) is a L2 switch with some VLAN config capability - in no aspect it can help to connect two modems to a single WAN router in a meaningful way.
