GazCBG
Mar 05, 2018Aspirant
Can I connect my mobile to provide internet via 4G on XR500 router?
Hi, I am thinking about buying a Netgear XR500, the one with the NetDuma OS and would like to know the following. Can I connect my mobile phone into the USB to provide internet through the mo...
- Mar 05, 2018Hi Gaz, great to hear you're thinking about getting the XR500.
There is no way to do that. I am unsure if it is possible to do that as I am not a developer. I will discuss with the team and see whether it is possible as if it is that's a great idea!
Netduma-Fraser
Mar 05, 2018NetDuma Partner
GazCBG
Mar 06, 2018Aspirant
Hi,
Thanks for the reply.
My current router (ASUS) has the option to do it via Dual WAN, which allowed a connection via ethernet (isp) and USB stick or phone and will fallover to it, if there internet drops.
At the time, my ISP went down, I connected it my Samsung S6 into the router using a USB cable and setting my phone to send 4G data through USB to the router. This in turn gave all PC connected to the router via Ethernet internet access.
Hopefully it be something you can add.
Thanks.
