GazCBG's avatar
GazCBG
Can I connect my mobile to provide internet via 4G on XR500 router?
Hi,   I am thinking about buying a Netgear XR500, the one with the NetDuma OS and would like to know the following.   Can I connect my mobile phone into the USB to provide internet through the mo...
  • Netduma-Fraser's avatar
    Mar 05, 2018
    Hi Gaz, great to hear you're thinking about getting the XR500.
    There is no way to do that. I am unsure if it is possible to do that as I am not a developer. I will discuss with the team and see whether it is possible as if it is that's a great idea!
