Jasonthecoolguy
Feb 03, 2021Follower
Can I plug a Netgear Nighthawk Pro XR500 directly into my console?
I an wondering if I can plug my Nighthawk Pro XR500 directly into my PS5.
michaelkenward
Feb 04, 2021Guru - Experienced User
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's impenetrable community structure.)
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Nighthawk Pro Gaming Routers - NETGEAR Communities
I will ask the Netgear moderator to move your message.
