Jasonthecoolguy
Feb 03, 2021Follower
Can I plug a Netgear Nighthawk Pro XR500 directly into my console?
I an wondering if I can plug my Nighthawk Pro XR500 directly into my PS5.
pkgadd
Feb 03, 2021Luminary
It's more of the other way round, as the xr500 acts as router (and AP), while the console is the client connecting through it to get internet access - but, yes. You obviously can connect your console directly via ethernet to one of the 4 ethernet ports of your xr500 - this should always be faster and more reliable than using a wireless connection.
Netduma-Fraser
Feb 04, 2021NetDuma Partner
Good advice above but yes you can connect the console to the router.
