Shedding
Jul 20, 2019Tutor
Can I see my kids web history? Xr700
I used to have an Asus router which allows me to view my kids web history. Does the XR700 have something similar?
Netduma_Alex
Jul 22, 2019NetDuma Partner
No sadly not, but it's something we're interested in adding.
I wonder if you'd be interested in me putting you in contact with the DumaOS devs? We're currently looking for people who can tell us what they would like to see from a Parental Controls solution on DumaOS. What they've found useful in other Parental Controls products, what they'd like to see improved.
Let me know if that's something you'd be interested in!
schumaku
Jul 22, 2019Guru - Experienced User
No way to trace the exact Web history on Https connections - all you can do is to capture the DNS A and AAAA lookups and assume these are Web and other (like App API and the like) connections .... at least as long as there is no DNScrypt or the kids start using a VPN. Either case, you will be blind in both eyes. It's a war parents and IT security people to some extent can't win.
You have to look on the client platform - there you can capture the browsers FQDN (but nothing more!).
