Paras123
Jul 10, 2019Aspirant
can i use a gaming router (XR500) on a 2 in 1 modem ?
can i use a gaming router (XR500) on 2 in 1 Netgear router and if so whats the right way to do it/set it up?
1 Reply
- Netduma_AlexNetDuma Partner
Do you mean you want to use the software on a different product? Because the DumaOS software is only available on the XR300, XR450, XR500 and XR700.
If you mean "will it work with a combined modem and router?" then yes it will, but you might need to set the modem to bridge mode or put the XR500 into the DMZ of the upstream modem/router.
