Paras123
Jul 09, 2019Aspirant
can i use a router with a gateway modem
can i use a gaming router with a gatway modem from comcast ?
Jul 09, 2019Guru - Experienced User
Yes.
With that said, if you truly want the gaming capabilities of the router, you'll need to make sure that if comcasts gateway device has an integrated router (combo device), that you disable that part of it. Or you can put the gaming router in AP mode but you loose the whole purpose of a gaming router.
More details such as model numbers would help to be more specific.
Netduma_Alex
Jul 10, 2019NetDuma Partner
You should post this in the correct forum for your model: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
