Kirbiie
Jan 07, 2020Tutor
Can I use two Nighthawks as a Mesh System?
I accidently bought two Nighthawk routers from Amazon. Can I use them together as a Mesh Network. Please forgive me if this sounds ridiculous but I feel like I seen someone do this somewhere. Th...
Netduma_Alex
Jan 08, 2020NetDuma Partner
I don't believe this is a supported feature. I know that you can use an XR500 with an EX7700 to make a mesh network.
Newfiedrool
Jan 09, 2020Virtuoso
If it helps the EX8000 works with the XR500 as well.
- KirbiieJan 09, 2020Tutor
That is definitely very helpful. Thank you much!
