Breebz
Mar 23, 2020Aspirant
can not connect to router interface
I purchased this today and for the last 4 hours have been trying to set this up via the ios app and through pc. I previously had the Nighthawk x4s which worked great. The phone app states it can no...
Breebz
Mar 24, 2020Aspirant
My ISP does not require a modem. The internet is connected to the yellow port on the back of the XR500. I have internet - just can not access the routers UI. Where do I find the Settings - Advanced - IPV6 that you are speaking of?
Netduma-Fraser
Mar 24, 2020NetDuma Partner
What is your XR500 connected to - an ONT or a wire from the wall? How are you attempting to access the interface? You should be able to access it through routerlogin.net or the default IP either 192.168.1.1 or 10.0.0.1. You will then need to go through the setup wizard before you have internet/can access the interface fully.
