onisius
Apr 24, 2019Follower
can not connect to router
cant even ping it on cmd never opens the start assistant or the dashboard just keeps giving me a can not connect 192.168.1.1 and .0.1 do the same i can manually go in through a hard cable but its sup...
Apr 24, 2019Guru - Experienced User
Have you tried resetting the device?
What firmware is it on?
- Netduma_JackApr 25, 2019NetDuma Partner
How are you connecting to the router?
Can you connect by typing in routerlogin.net ?
Might be worth contacting NETGEAR's official support too: https://www.netgear.com/support/contact.aspx
