usermac's avatar
usermac
Luminary
Jan 30, 2019
Can the XR500 PREVENT LAGG AT THE SAME TIME AS STREAMING TO TWITCH ?
Is it possible to have the Duma OS set up in a way that say if you are streaming your game to twitch you can still maintain a good quality connection ?
I am asking because I tried testing this whilst playing Battlefield V and streaming to twitch but I get constant ping spikes and packet loss warnings and same for PUBG.
My connection is 80mb down 20mb up and the QOS is set to 70/70 with high priority also set to kick in when high traffic is detected.
I am using a gaming PC but with the gaming PC set as a console.
Battlefield V, Discord and OBS Studio is what is using the connection.
  • Hi there - yes, it absolutely should.
    Could you try switching Anti-Bufferbloat to the 'Always' mode. And could you also disable DumaOS Classified Games in Traffic Prioritisation.
    Does that improve things?
    Also, is your PC wired or wireless?
    • usermac's avatar
      usermac
      Luminary
      Hello Jack
      My connection is wired I can not see much difference with those settings to be honest should there be some fluctuation on my ping if streaming as well ?
      Just my ping when not streaming is usually 10 ms and remains that way but when streaming as well the ping constantly changes up and down they are not high numbers but it goes like 10ms, then maybe 12ms then 22ms and maybe 50ms then back down to 10ms never settles.
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        Lets first get a bit more of an idea about your setup. What's your physical setup? E.g. ISP hub (some devices connected) > XR500 (wired devices connected) etc
        Have you put the full speeds you normally get into Anti-Bufferbloats options so it's working off the correct information?
        Your ping to go up in that scenario is normal and QoS should be keeping it mostly down.
