Gimli
Apr 19, 2018Tutor
Can this router be used in any country
Can this router be used in any country? Thank You!!!
Netduma-Fraser
Apr 19, 2018NetDuma Partner
Yes it can be used in any country. You should check WiFi channel restrictions that your country may have also.
- GimliApr 20, 2018Tutor
I live in another country, my cousin bought this router for me. If it comes with problems of connection drops, reboot or speed problems, things reported here.
What do I have to do? Send back to the United States?- Netduma_JackApr 21, 2018NetDuma Partner
That would be up to the returns policy of the retailer your cousin purchased it from
- GimliApr 22, 2018Tutor
But he will bring it to me and it will be too much work to send back to the United States, I hope not to disappoint with the netgear.
I lost an ASUS AC5300 WiFi Tri-band, stopped working out of nowhere, took a technician and found no reason for electric discharge.
Looks like I kept a cooler base under this Asus to avoid overheating
- schumakuApr 23, 2018Guru - Experienced User
Netduma-Fraser wrote:
Yes it can be used in any country. You should check WiFi channel restrictions that your country may have also.Do all the XR500 (the mass production units) variants support changing the country settings, so the correct channel/DFS/TFS/power settings are active, and the correct country is advertised with the beacon?
- Netduma-FraserApr 23, 2018NetDuma PartnerI believe they're region locked but can't say for sure.
I believe they're region locked but can't say for sure.This would be prohibitive. Needless to say - this does and will lead to consumers operating routers in illegal configurations.
PS. Quoting with "@ username" link is still prohibied, too.
