Gimli
Apr 19, 2018Tutor
Can this router be used in any country
Can this router be used in any country? Thank You!!!
Netduma-Fraser
Apr 19, 2018NetDuma Partner
Yes it can be used in any country. You should check WiFi channel restrictions that your country may have also.
Gimli
Apr 20, 2018Tutor
I live in another country, my cousin bought this router for me. If it comes with problems of connection drops, reboot or speed problems, things reported here.
What do I have to do? Send back to the United States?
- Netduma_JackApr 21, 2018NetDuma Partner
That would be up to the returns policy of the retailer your cousin purchased it from
- GimliApr 22, 2018Tutor
But he will bring it to me and it will be too much work to send back to the United States, I hope not to disappoint with the netgear.
I lost an ASUS AC5300 WiFi Tri-band, stopped working out of nowhere, took a technician and found no reason for electric discharge.
Looks like I kept a cooler base under this Asus to avoid overheating
