Gimli
Apr 19, 2018Tutor
Can this router be used in any country
Can this router be used in any country? Thank You!!!
Netduma-Fraser
Apr 19, 2018NetDuma Partner
Yes it can be used in any country. You should check WiFi channel restrictions that your country may have also.
schumaku
Apr 23, 2018Guru - Experienced User
Do all the XR500 (the mass production units) variants support changing the country settings, so the correct channel/DFS/TFS/power settings are active, and the correct country is advertised with the beacon?
