Gimli
Apr 19, 2018Tutor
Can this router be used in any country
Can this router be used in any country? Thank You!!!
schumaku
Apr 23, 2018Guru - Experienced User
Netduma-Fraser wrote:
Yes it can be used in any country. You should check WiFi channel restrictions that your country may have also.
Do all the XR500 (the mass production units) variants support changing the country settings, so the correct channel/DFS/TFS/power settings are active, and the correct country is advertised with the beacon?
Netduma-Fraser
Apr 23, 2018NetDuma Partner
I believe they're region locked but can't say for sure.
- schumakuApr 23, 2018Guru - Experienced User
I believe they're region locked but can't say for sure.This would be prohibitive. Needless to say - this does and will lead to consumers operating routers in illegal configurations.
PS. Quoting with "@ username" link is still prohibied, too.- BretDApr 23, 2018Administrator
I'm not having trouble @ someone's username. Have you checked your user settings page?
Thanks!
Bret,
Use the [Quote] button in the rich text editor ...
BretD wrote:@I'm not having trouble @ someone's username. Have you checked your user settings page?
Thanks!
...this quote will no go through. I've modeed the two by edititing, so the link is no longer a link.
[image stripped here]
...and on [Post], the two automatically generated quotes are removed, strippd by some HTML checking...
[second image stripped here, too]It's not a question of my community settings - this does work all-over - but not in the Nighthawk Pro Gaming sub-fora.
Also the two emebedded pictures are stripped.
PS. Quoting with "@ username" link is still prohibied, too.Just testing a "quote".
