Bryce123
Sep 17, 2018Follower
Can u use the nighthawk with a phone service
Can u use the nighthawk with a phone service like sprint, Verizon, etc
Netduma_Jack
Sep 18, 2018NetDuma Partner
This should work, yes - so long as your phone has wireless capability (or is a wired VOIP phone) then you'll be able to use it no problem with a Nighthawk of any type.
I hope this helps!
