Ricksta72
Apr 21, 2021Guide
Can XR500 connect to bt homehub 5?
Thinking about picking an XR500 up from Argos, but i need to know if it will connect directly to my bt homehub 5 or will i need a modem? any help is appreciated
- Apr 21, 2021
Thanks for your interest!
You shouldn't have any issues connecting the XR to the home hub. However, if you do feel free to update us here and we'd be happy to assist!
Ricksta72
Apr 21, 2021Guide
Awesome thanks Liam
Apr 21, 2021Guru - Experienced User
The homehub has its own integrated router functions.
When you connect the XR500 to it, make sure to put the XR500's IP address into the homehubs DMZ.
- Ricksta72Apr 21, 2021GuideOk then after doing that it should all work fine?
- Ricksta72Apr 21, 2021GuideDo i just put an ethernet cable from the homehub ethernet port to the XR500 Internet port?
- Netduma-FraserApr 21, 2021NetDuma PartnerYes it will. Yes that's correct!
