adamzimb
Nov 27, 2018Guide
can XR500 handle 1gbps from ISP?
I recently upgrade my internet package to 960+ mbps download and 50 upload. Technician had issues going beyond 330-350 range which was the range of my old package.
Tech called it in to make su...
Netduma-Fraser
Nov 27, 2018NetDuma Partner
Yes it should be able to handle gigabit speeds. So you're saying with QoS completely disabled in Anti-Bufferbloats settings that you're not reaching those speeds on a wired PC speed test?
adamzimb
Nov 27, 2018Guide
Oh that was a general question of asking still. I just want to ask now if this is capable cause I dont want my ISP to blame the router.
Thanks.
Thanks.
- LeeboNov 28, 2018Aspirant
Hi I have the same issue , recently upgraded to the 1gig package and I’m only getting 350 ish from the speed tests from this router, had the isp on the phone nd there saying my ont profile has been updated and reset twice but still the same speeds , I have disabled qos and no difference at all , have updated the new speeds in the part where you tell it’s the speed of your internet , but should not matter as all my qos is disabled
im at a lost now any help
is it the firmware ? Any new beta out there to check
- Netduma-FraserNov 28, 2018NetDuma PartnerAre you doing the tests through a wired connection?
Yes wired and on the 5g wireless connection and get no faster then 350
