adamzimb
Nov 27, 2018Guide
can XR500 handle 1gbps from ISP?
I recently upgrade my internet package to 960+ mbps download and 50 upload. Technician had issues going beyond 330-350 range which was the range of my old package.
Tech called it in to make su...
Netduma-Fraser
Nov 27, 2018NetDuma Partner
Yes it should be able to handle gigabit speeds. So you're saying with QoS completely disabled in Anti-Bufferbloats settings that you're not reaching those speeds on a wired PC speed test?
adamzimb
Nov 29, 2018Guide
Guess since I was viewing through mobile I didnt see the 2nd part of your message.
I have it wired via cat6 cable.
I did try to have the modem connect directly to my PC but it didn't work at all lol.
QoS has always been turned off but I will check again
