CoolestJake
Feb 22, 2021Guide
Can you connecting XR500 to XR300 wirelessly?
Hello, I have a XR500 connected to a gateway. I just recently got a XR300 from a friend and I want to put it downstairs so I can get a better connection downstairs. I know that you can put it in AP mo...
- Feb 23, 2021So then I’m guessing because the xr300 doesn’t have a wireless repeater that I can’t connect them wirelessly and when I look in the settings for the XR500 it doesn’t seem to have a wireless repeating mode either. If I’m correct then the only way would be to run a ethernet cable through the floor?
Feb 23, 2021Guru - Experienced User
I've seen it with homes that setup the basement for a seperate living quarters to rent out. Or for a mother in law suite in the basement.
Not common but does happen.
CoolestJake
Feb 23, 2021Guide
