RickyRouter
May 18, 2018Tutor
cannot access xr500 router
Hello,
I just installed my xr500 router, which runs to a Arris DOCSIS 3.0 cable modem.
I am online (clearly) but I cannot access the router's GUI.
I tried 192.168.1.1 - I tried www....
RickyRouter
May 18, 2018Tutor
Here is the screen it stalls at after I enter my credentials..
BIG_DOG
May 18, 2018Luminary
hi
Hope this is of help to you.......... it is not routerlogin.com but routerlogin.net I recommend flushing your browsers cache then try that address.
Hope that helps you.
- RickyRouterMay 18, 2018Tutor
flushed DNS and yes, my apologies. I meant .net
gateway address and routerlogin.net - neither works.- RickyRouterMay 18, 2018Tutor
www.routerlogin.net ---> enter credentials ---> get all white screen.
*See attached file..
Note: every so often, I get an all, dark red screen. See previous attachment- RickyRouterMay 18, 2018Tutor
Dang.. file didnt attach..
round 2
