OldNostalgic
Nov 27, 2019Aspirant
Cannot access XR700 login on PC, or iPad or iPhone other than Firefox on iPad and iPhone
So the only way I can access the routers setup page is via an iPad or iPhone with Firefox. If try any other browser on iPad or iPhone I get asked to enter password trice then say invalid password, (S...
Netduma-Fraser
Nov 27, 2019NetDuma Partner
How are you accessing via the PC - HTTP or HTTPS? Routerlogin.net or LAN IP? Is there any difference between these methods and the result you get?
OldNostalgic
All url in PC browser give same result, of 'Unable to Connect'.
- Netduma-FraserNov 27, 2019NetDuma PartnerCould you attach a screenshot of this so we can see whats happening exactly please?
- OldNostalgicNov 28, 2019Aspirant
Cannot ping 192.168.0.1 from PC. Simple. Browser cannot see 192.168.0.1. Simple. Will send screen shot tonight but wont help. Typed a random address into work PC to get same message:
- Netduma-FraserNov 28, 2019NetDuma PartnerWhen connected to the router via ethernet can you open a command prompt and then type ipconfig and then press enter and post a screenshot of the results here please?
