TrubbleMaker
Oct 10, 2022Tutor
Cannot change IP address in the XR500
Hi guys I'm new to the XR500 device. I cannot change the default IP address from 192.168.1.1 to 192.168.10.1 The router is running Firmware Version 2.3.2.134. When I change the IP address to 1...
- Oct 10, 2022
UPDATE: It's almost 2:00AM here at the epicentre of the known universe (Sydney, Australia... where God LIVES!!)
My brain is now officially mush and I have no idea how I did it, but I managed to get the IP address changed and it stuck!! WOOOHOOO! đ
I know somewhere in there I flashed the firmware twice and also did two factory resets.
After the second factory reset, I managed to get the change in the IP to stick and not bring up the 'Bad Gateway' error but then it hung while rebooting so I manually rebooted the the router and then found the change had finally worked.
I know I should have kept better notes of what I did but after fartarsing around for waaaaay too many hours I was well and truly over it.
Thank you all for your your suggestions , your time and your patience.
CheersCharlton đ
TrubbleMaker
Oct 10, 2022Tutor
"What browser are you trying to do this from? A 400 error would suggest it's a client side issue so we should start there. Does it work if you use an incognito/private window to do this? Or perhaps a different browser all together?"
I've tried Chrome and Brave
Netduma-Fraser
Oct 10, 2022NetDuma Partner
Good suggestion above, also, just to check, what is the IP to access the modem the XR is connected to?
