TrubbleMaker
Oct 10, 2022Tutor
Cannot change IP address in the XR500
Hi guys I'm new to the XR500 device. I cannot change the default IP address from 192.168.1.1 to 192.168.10.1 The router is running Firmware Version 2.3.2.134. When I change the IP address to 1...
- Oct 10, 2022
UPDATE: It's almost 2:00AM here at the epicentre of the known universe (Sydney, Australia... where God LIVES!!)
My brain is now officially mush and I have no idea how I did it, but I managed to get the IP address changed and it stuck!! WOOOHOOO! 😁
I know somewhere in there I flashed the firmware twice and also did two factory resets.
After the second factory reset, I managed to get the change in the IP to stick and not bring up the 'Bad Gateway' error but then it hung while rebooting so I manually rebooted the the router and then found the change had finally worked.
I know I should have kept better notes of what I did but after fartarsing around for waaaaay too many hours I was well and truly over it.
Thank you all for your your suggestions , your time and your patience.
CheersCharlton 🙂
TrubbleMaker
Oct 10, 2022Tutor
Cheers
Charlton 🙂
Oct 10, 2022Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
