Octobermom
Jan 21, 2019Follower
Cannot connect all my wireless devices to XR450
Installed router yesterday. Did get a speed bump from 130/6 to 180/6 but only 18 out of around 60 devices would connect. I factory reset and reset the router multiple times and finally everything c...
Jan 21, 2019Guru - Experienced User
I have about 35 devices connected with my XR450. However about 20 of those are wireless only. 60 devices maybe to many for a single dual band router.Maybe one reason why your prior router died. Possible you may need to off load to help with band width maximums and the ability to connect all devices wirelessly. Something like a EX7700 or EX8000 maybe needed.
I recommend wiring the game console as well. Wired is preferred for gaming.
Is Beamforming and MIMO enabled?
How about Airtime Fairness?
- Netduma_JackJan 23, 2019NetDuma Partner
You should still be ok to connect all these devices - the XR450 can handle many, many devices (NETGEAR test for this).
Do you have Smart Connect enabled? It might be worth disabling this and just picking and choosing which devices you want on each band to reduce the pressure on one band.
It's worth also trying to avoid using a congested channel, for example, channel 11 is usually a congested channel for 2.4GHz (you can use a free WiFi scanner to find the best channel)
