Paul1111111
Jul 14, 2023Aspirant
cannot connect to interner
My XR300 router in AP mode is connected to the internet. I can connect to the router on the WIFI guest network to the internet. If i add a password to the guest network i cannot connect anymore beca...
Paul1111111
I did have it on normal mode, but it didn't work then also. I changed it at the shop for a new one, but the problem remains.
I could log on to the wifi, but when i changed the password it stoped connecting my PC to the router.
Jul 14, 2023Guru - Experienced User
More than likely because you gateway has its own built in router.
When you setup the xr300 in router mode, you'd want to put its ip address into the livebox's dmz
