mcguinnessk's avatar
mcguinnessk
Follower
Oct 10, 2024
Cannot connect to internet: after moving rooms, my NETGEAR nighthawk xr1000 will not connect to the
Please help,
I recently moved my NETGEAR router, to get a better internet signal, however, had no success. I moved it back to its original place and cannot connect to the internet. I have done a reset of the router, followed the NETGEAR app connection process several times but still cannot connect.
  • plemans's avatar
    whats the XR1000 connected to for modem/gateway? That's the questions
  • So just to clarify you have gone through and completed the Setup Wizard? If so reboot your modem, wait 2 minutes then reboot the XR, wait 2 minutes then check again please
