raymondo111
Jul 28, 2025Aspirant
Cannot connect to most EU community servers in Valve Games
Having issues with connecting to most if not all EU community servers in CS2 and even other games. I am using a XR1000v2 and its firmware is upto date, and strict mode on geo filter is already disabl...
- Aug 01, 2025
so ive found the solution. recently a online safety act was passed in the uk, which is interfering with the connection of certain ips which can only be bypassed via vpn etc.
raymondo111
I believe ive disabled it, but im truly unsure of how to do it.
Netduma-Fraser
Jul 28, 2025NetDuma Partner
At the top of the page where you've added your device switch Filtering off/switch to Spectating Mode or just delete the device you've added there
- raymondo111Jul 28, 2025Aspirant
yeah there are no devices added there, and i added and even disabled the filtering and tried it too, it still doesnt work
- Netduma-FraserJul 28, 2025NetDuma Partner
Connect your PC directly to your ISP modem/router so you bypass the XR1000, do you still have the issue then?
The issue doesn't persist if I do this.
