mr_nguyen's avatar
mr_nguyen
Cannot connect to router login after latest firmware update
Hi,   I have a netgear XR1000 and after updating the latest firmware I can not login in to the router admin.    I appreciate any thought and feedback on this issue.
  • Netduma-Liam's avatar
    Netduma-Liam
    Jul 12, 2022
    If you mean to say that you still cannot login to the router, could you please clear your browser's cache after the reset, you should then be met with the setup wizard when you try to access the router's admin interface.
