jesse8472
Jan 30, 2020Aspirant
cannot connect to specific website
cannot connect to specific everything else is fine. i have rebooted, updated firmware, change dns, flush dns, if i plug in to the modem i can get to the website. can anyone help please?
Netduma-Fraser
Jan 30, 2020NetDuma Partner
Have you added any websites to the block sites options in the Settings page?
jesse8472
yes and now i have done a factory reset now still nothing.
- Netduma-FraserJan 30, 2020NetDuma PartnerWithout changing anything after the reset it is still the same? Weird that it is fine with the modem though. Is it blocked on wifi and ethernet? Does it occur on other devices as well?
- jesse8472Jan 30, 2020Aspirant
all devices on the network both wired or wifi can not reach the website. if i get on my phone off the network i can reach it.
- Netduma_AlexJan 31, 2020NetDuma Partner
Here's a suggestion, on your computer, open Command Line and type:
ipconfig /flushdns
