lI_SimoHayha_Il
Dec 02, 2023Aspirant
Cannot connect to VPN from my iPhone
I had a Nighthawk X4S that was working great. However I decided to get an XR1000V2, just for the Gaming options and faster Wi-Fi Most things work great, some minor issues, but my main problem is the...
Netduma-Fraser
Dec 02, 2023NetDuma Partner
I'm not sure what the default mode the config is set to but you'll need to adjust it to TUN then connect and it should work. It's a Netgear feature so if that doesn't work it may be best to create a ticket with them directly.
- lI_SimoHayha_IlDec 02, 2023Aspirant
"but you'll need to adjust it to TUN"
Not sure what you mean? Can you please elaborate?
- Netduma-FraserDec 02, 2023NetDuma PartnerThe config you download for the phone, open it in a text editor like Notepad then it should say TUN or TAP at the top, make the change if needed, save then use that saved config
client dev tun proto tcp remote xxxxxx 12973 resolv-retry infinite nobind persist-key persist-tun
