lI_SimoHayha_Il
Dec 02, 2023Aspirant
Cannot connect to VPN from my iPhone
I had a Nighthawk X4S that was working great. However I decided to get an XR1000V2, just for the Gaming options and faster Wi-Fi Most things work great, some minor issues, but my main problem is the...
lI_SimoHayha_Il
"but you'll need to adjust it to TUN"
Not sure what you mean? Can you please elaborate?
Netduma-Fraser
Dec 02, 2023NetDuma Partner
The config you download for the phone, open it in a text editor like Notepad then it should say TUN or TAP at the top, make the change if needed, save then use that saved config
- lI_SimoHayha_IlDec 02, 2023Aspirant
client dev tun proto tcp remote xxxxxx 12973 resolv-retry infinite nobind persist-key persist-tun- Netduma-FraserDec 02, 2023NetDuma PartnerIs that the downloaded config or you've changed it? Either way that portion of it looks correct
- lI_SimoHayha_IlDec 03, 2023Aspirant
This is what is downloaded and imported on my phone.
Unfortunately I don't have the old one from X4S, to compare them though.
