borngolfer
Sep 25, 2021Guide
Cannot connect XR1000-100CNS Router to Bell Home Hub 4000
I just bought an XR1000 Wi-Fi 6 router and have been trying to connect it to my Bell Home Hub 4000 via a cable that came with the XR1000. The internet would not connect and the "internet" light stays...
borngolfer
Sep 25, 2021Guide
Thanks. Yeah, I did all that it still shows as no internet on the app.I tried all the different connection options on the app and still cannot get it to work. They are both WiFi 6 units so should be compatible.
Netduma-Fraser
Sep 25, 2021NetDuma Partner
So you're doing the setup via the app? If you access the interface on a PC has the setup complete? Do you get a WAN IP on the System Information page?
