Nozys
Feb 24, 2019Follower
Cannot connect
I cannot connect to the router settings using default gateway, or using Routerlogin.com. I have packet loss. And I can connect to the actual network on pc. But not on me or my brothers phone.
Feb 24, 2019Guru - Experienced User
What FW is currently loaded?
- Netduma-FraserFeb 24, 2019NetDuma PartnerWhen did this start to occur? Did you go through the setup wizard successfully?
