HiImBarryScott
Mar 31, 2018Aspirant
Cannot get network prioritisation to work properly (XR500)
Hi everyone, I recently bought a XR500 Nighthawk gaming router. I cannot however get the network traffic prioritisation to work properly. Sometimes it picks up game traffic (Blizzard launcher) bu...
Dust123
Sep 22, 2018Aspirant
priority packets not woking for PC battfield 1
i have called and went through all options ports dont work either
Netduma_Jack
Sep 23, 2018NetDuma Partner
Which DumaOS version are you on? If you click the ‘i’ icon at the top it will show you. If it does not end in .32, could you upgrade please:
https://kb.netgear.com/000060127/XR500-Firmware-Version-2-3-2-32
- Dust123Sep 23, 2018Aspirant
yes i have the most current version of the software
i will not detect battfiled 1 game packets
- Netduma-FraserSep 23, 2018NetDuma PartnerIf the manual ports aren't working then you have either not selected the correct device or the ports are incorrect. Double check correct device has been selecting by comparing the name/IP in device manager to IP PC is showing and double check ports on the Battlefield site for PC.
