HiImBarryScott
Mar 31, 2018Aspirant
Cannot get network prioritisation to work properly (XR500)
Hi everyone, I recently bought a XR500 Nighthawk gaming router. I cannot however get the network traffic prioritisation to work properly. Sometimes it picks up game traffic (Blizzard launcher) bu...
Netduma_Jack
Sep 23, 2018NetDuma Partner
Which DumaOS version are you on? If you click the āiā icon at the top it will show you. If it does not end in .32, could you upgrade please:
https://kb.netgear.com/000060127/XR500-Firmware-Version-2-3-2-32
Dust123
Sep 23, 2018Aspirant
yes i have the most current version of the software
- Dust123Sep 23, 2018Aspirant
i will not detect battfiled 1 game packets
- Netduma-FraserSep 23, 2018NetDuma PartnerIf the manual ports aren't working then you have either not selected the correct device or the ports are incorrect. Double check correct device has been selecting by comparing the name/IP in device manager to IP PC is showing and double check ports on the Battlefield site for PC.
- Dust123Sep 23, 2018AspirantCould it have anything to do with my Ethernet port settings? Previously made some changes. Any settings in particular that could interfere with packet detection?
- Dust123Sep 23, 2018AspirantStill not working I have tried everything and I am not new to networking. It picks up the Xbox but not the PC for Battlefiled 1
- Netduma-FraserSep 24, 2018NetDuma PartnerCould you provide a screenshot of the Traffic Prioritization feature please?
- Dust123Sep 24, 2018AspirantFYI
For you future trouble shooting I figured it out even though it is not battlefield selected I switched it to PC / game console and it is now picking up the traffic for battlefield ?- Netduma-FraserSep 24, 2018NetDuma PartnerThat's an alternative solution as the games console service encompasses a very wide range of ports. It'll definitely work that way but may prioritize other traffic from your PC also.
