ItsMeDan
Dec 26, 2018Guide
Cannot VPN some devices
Hi Just wondering, I have managed to use Hybrid VPN with some of my devices, like computers and Macs, but if trying to VPN something like an Xbox it stays shaded out and you cannot seem to do anythin...
Netduma-Fraser
Dec 29, 2018NetDuma Partner
Yes the entire Xbox is being VPN'd. We do this because we can't detect individual services on a console like a PC.
- ItsMeDanDec 29, 2018GuideAwesome thanks for the reply. Happy I can VPN from the router using my provider NordVPN.
Thanks
Dan- ItsMeDanJan 19, 2019Guide
Hi,
Just wondering and instead of starting a new thread. Should the VPN be reconnecting automatically if it drops out.
At the moment it drops connection and doesn't seem to reconnect.
Thanks
Dan
- Netduma_JackJan 21, 2019NetDuma Partner
Hi Dan,
I'm not actually sure - I would need to check with the dev but he's not in today. Are you having regular VPN drops? If so, it's probably worth using a different server of even different provider if possible.
