ItsMeDan
Dec 26, 2018Guide
Cannot VPN some devices
Hi Just wondering, I have managed to use Hybrid VPN with some of my devices, like computers and Macs, but if trying to VPN something like an Xbox it stays shaded out and you cannot seem to do anythin...
ItsMeDan
Dec 29, 2018Guide
Awesome thanks for the reply. Happy I can VPN from the router using my provider NordVPN.
Thanks
Dan
Thanks
Dan
ItsMeDan
Jan 19, 2019Guide
Hi,
Just wondering and instead of starting a new thread. Should the VPN be reconnecting automatically if it drops out.
At the moment it drops connection and doesn't seem to reconnect.
Thanks
Dan
- Netduma_JackJan 21, 2019NetDuma Partner
Hi Dan,
I'm not actually sure - I would need to check with the dev but he's not in today. Are you having regular VPN drops? If so, it's probably worth using a different server of even different provider if possible.
- ItsMeDanJan 21, 2019Guide
Ok, thanks. It normally works fine on other devices. Only via the router, it drops out, and if it drops out the traffic stops as it is meant to due to the setting I have.
An auto reconnect would be good though. I will try one of their other servers and see.
Thanks
Dan
- Netduma_JackJan 23, 2019NetDuma Partner
Thanks Dan - hope that one works better for you
