scottie2hottie
May 13, 2018Tutor
Can't access the Router Login page
Hi just purchased this router a day ago now no pronlems apart from cant login to the router itself
after ive put admin and password in all i get is this message wich says it keeps refreshing all th...
Netduma-Fraser
May 13, 2018NetDuma Partner
Go to routerlogin.net/index.htm > Administration > Backup Settings and click erase to do a factory reset, that should fix the issue.
- scottie2hottieMay 13, 2018Tutor
just tried that all im getting is a blank white screen.
- Netduma-FraserMay 13, 2018NetDuma PartnerWhat firmware version are you on and what did you do prior to the issue occurring?
v2.2.1.10
thanks for your help im all sorted now did the factory reset all sorted.
