scottie2hottie
May 13, 2018Tutor
Can't access the Router Login page
Hi just purchased this router a day ago now no pronlems apart from cant login to the router itself
after ive put admin and password in all i get is this message wich says it keeps refreshing all th...
Netduma-Fraser
May 13, 2018NetDuma Partner
Go to routerlogin.net/index.htm > Administration > Backup Settings and click erase to do a factory reset, that should fix the issue.
scottie2hottie
May 13, 2018Tutor
just tried that all im getting is a blank white screen.
- Netduma-FraserMay 13, 2018NetDuma PartnerWhat firmware version are you on and what did you do prior to the issue occurring?
- scottie2hottieMay 13, 2018Tutor
v2.2.1.10
thanks for your help im all sorted now did the factory reset all sorted.
